superheat6k
My Stbd engine through its drive belt today after a somewhat bumpy crossing from the Needles to Poole.
About an hour before we entered the channel I noticed a jingling sound from the engine bay but could see anything wrong, so plodded on in a nasty southerly swell (crossing the Bridge at the Needles was bloody awful !). Then as we came up the Poole approach channel I opened the engines up to clean off the turbos after 2 hours at moderate revs, when in short order the generator warning light came on then the stbd engine overheated, so I knew straight away the belt had gone.
Thanks to Poole Quay Yacht Haven staff who sent out a posse to help me alongside a simple to get to berth at the entrance.
Then found most of the coolant in the bilge with the belt detached but not snapped. Instead the alternator drive pulley was loose, but the nut was bar taut on the shaft. Managed to get it undone, checked the shaft and re-did it up with plenty of loctite 242, but found it odd that the nut was so tight on the shaft even though it was about two turns loose.
Replaced the belt with a new spare (both engines).
Cummins 6BT5.9M engines ...
1 I noticed about 1-2mm run out on the re-mounted driver pulley on the alternator. Views as to whether this is excessive please.
2 The new ribbed belts were extremely tight to fit with the idler tensioning pulley at max deflection to get the belt on, and only fell back about 15mm from its loosest position as it took the tension up. So as long as the idler moves back a distance is the tension OK.
3 The overheating took the temperature gauge up to 105oC, bit all seems fine after the belt was replaced and the coolant replaced (the qty that leaked came from the pressure cap). Anything else I need to pay attention to on a Cummins 6BT after such an overheat. The engine was shut down within 1 minute of the alternator alarm sounding,
