ripvan1
There was a thread some time ago calculating how much would be collected if there was a drip every ? seconds - anyone remember it and care to provide a link or how much fluid an average drip contains
There was a thread some time ago calculating how much would be collected if there was a drip every ? seconds - anyone remember it and care to provide a link or how much fluid an average drip contains![]()
ripvan1,
I hate to spoil your sleep but surely a drip can only get worse; or is this just overnight before sorting it ?
Seajet, thanks for your concern, put new stern tube and shaft in today between tides to see how she likes it - some more adjustment and tightening tomorrow should hopefully sort it.
Using VicS rate is 3.6l per tide, 7.2 per day, near 50l a week. Get it fixed soon! Better still invest in a stern tube seal that does not leak.
On the IV prescription charts I use at work the stated amounts are 20 drops per ml.
Please do not rely on this but we had a drip every 10 seconds or so from our stern gland before I had it restuffed. Suprisingly little collected in the bilges over a two week period. Suspect that maybe the drip slowed down as I used to check an hour or two after the engine was run. Seem to recall that they are supposed to drip a bit .....Thanks Vics, I can sleep tonite now - I've got a drip every 6 seconds through stern tube on drying mooring probably wet 6 out of 12 hours - thanks again.
.... Seem to recall that they are supposed to drip a bit .....
That sounds reassuring as my new stuffing does not drip at all. Had it replaced by our (excellent) boat yard and now it accepts exactly half of turn of the greaser after each trip as I think it is supposed to. I am now glad I did not try to do it myself as when I did it last time it would take as much grease as you cared to give it - the greaser just went round and round so I assume the grease escaped and went somewhere !They are with older type packings which I think required water for better lubrication, modern packings that have a lower coefficient of friction are supposed to be dripless, as mine is.
You learn something new every day. I thought a water drop was always the same size, independent of the dropper.In the lab one normally reckons that 1drip from for example the jet of a burette tap is 0.05ml. and I expect the same with your IV drip equipment where the drips fall from a narrow tube...
