Greenheart
My main & genoa halyards emerge from the centre of the mast-foot, then turn through a very awkward diagonal to reach their clam cleats, just a few inches above. Everything about hoisting & lowering is made harder by the unnatural corner they take.
It wouldn't be hard to drill four new holes about 15" above the mast-foot sheaves, allowing me to cleat the sheets then yank on the tensioned section to get the sails that bit higher; and slackening/lowering them would be much less effort too.
Given that rivet (or bolt) holes for the clam cleats will only be around 3mm across, is there any good reason not to drill new ones?
I can't work out why the mast's maker (or the dinghy's designer) chose the present cleat locations. It's not as if there's no room for them elsewhere. Am I likely to regret making a change?
