stuartwineberg
About to fit a Garmin fishfinder. To run the cables I need a 5/8 (16mm) hole in the top surface of the dash - seems a lot but it is because of the width of the plugs already on the ends of the transducer and power cables. The dash is (I think) gel coated fibreglass or very thick plastic (3 or 4 mm). The drill bit size is too big for the chuck of my small drill and there isn't enough vertical clearance above the surface to fit in a large power drill and the bit.
My current thought is to drill the biggest hole I can with a smaller drill and then open it out with a round file by hand. That said, I look to the assembled expertise for a cleverer and easier solution
