vas
hi all,
Fabricated a hardtop for my mobo 4yrs ago, central section is cold formed inverted U shape approx 150X120mm made out of 2mm ss sheet.
Stupidly, I didn't specify drilling the two edges every 200mm with 4mm holes when it was still a flat sheet of metal, which I now need to do in order to screw and stress a thin black mesh material as a lining. I have 40x40mm iroko beams that I'll drill through and staple the material over and then tighten them on the frame to stretch the material properly. Led lighting in the U shape and a cover of them all in another iroko piece that will be lacquered -that's the plan at least!
Hard top is basically a frame with two 1X2m 300W ea solar panels which look awful from below, so need to cover all that.
Problem is that this thing now is at 2m from f/b floor with the panels on the top meaning I've got 2 strips of around 60-70mm high by 2m long to drill. Worse still is that I cannot get up on a chair or ladder to get the tool at chest height as there's no space for the rest of my body and head above (panels) Try as I may, using various drill bits (all decent quality cobalt ones at slow speed) I've not managed much - maybe 3 out of 20 odd holes I'd ideally like.
Ideally I'd like some way to secure the drill on the right spot so that I only need to press and not worry about moving about/breaking the bit, smashing the solar panel above...
Space is rather tight so I doubt fitting a double clamp on a table bench and securing it up there would work.
Hence the post, any smart idea I may be missing?
Even thought of messing the frame with the angle grinder, only slot will be rather thin and probably messy getting the drill to catch and complete a proper hole afterwards.
Last resort is getting my TIG welder on board with a properly shaped tungsten bit, high amps and drill (as in burn) messy holes in the ss
Really running out of ideas!
cheers
V.
cheers
V.
