DownWest
Bought a B&Q corded one about 16 yrs ago. €20 and it has done the odd job ever since. Money well spent. Came with a big bunch of bits and a flex extension.
Since I got a Li-Ion 75mm disc cutter/grinder, I'm using that for jobs which used to be a bit heavy for the dremel, like cutting SS machine screws to length.I have used the cordless models, and I think that might be part of the problem. They attempt to shave weight so that it is still light in the hand, which makes it under powered and prone to heating. Keep the cord. I don't understand the modern obsession with cordless everything.
I think the other problem may be use and run time. I only use a Dremel (light duty high speed rotary tool of any brand) for the lightest work, because it is a crafts tool. I use something more suited to the job for heavier things. IMO, there are very few uses for a Dremel on a boat.
Prob the answer is that any tool is a part of a range in ones kit. Use within it's limits and you will get good service. Push it too hard and....Funnily enough the Chinese offbrand ones that are visibly obvious clones of old (90s) Dremels seem to be about as good as the originals (ie - not great, but ok) but new Drems can be very flimsy.
I'm very happy with my Milwaukee 12v brushless die grinder, though time will tell whether I can keep working it as hard as I do...
Feel and judgement...OK, but on some tools the limits are so limiting I'll regret bothering with them at all, and on others, the limits are so broad that I get too used to them and overreach.
Battery Converter Adapter For Makita 18V Li-ion to for Parkside 20V Tool UK | eBaythe batterys for the portable look like Makita batterys - but are not compatible ...
The adapters do state "do not use for recharging batteries"
Strange ... wonder why ? The energy through while in use would be far greater than when being recharged. Interesting.
Could it be the adaptors are lacking a regulating terminal for "smart" charging, i.e. safe charging?
