pcatterall
Thanks to forum help I was able to identify the sea water drains on my TMP gearbox and the Perkins heat exchanger.
Although I am not winterising just now I thought I'd better make sure I could free all the drains ( a trial run) I was suprised at the amount of water which came out ( and would still be coming out if I hadnt shut it off)
Is it water being syphoned back from all the exhaust loops and traps?
I can say that there is definatly no water getting in via the sea cock nor is the engine coolant being affected.
Would it be an idea to shut the sea cock and run the engine for a minute to clear water from the system THEN drain the bits in the gear box and exchanger?
