DPE 2000 helmet sensor & leak
simonfraser
13 Mar 2004
Outboards 4 mobo’s, unless you do a lot of miles
Have managed to get grease in the bearing at last.
Expected it to come out by the shaft of the leg position sensor, but no, it’s come out of the top of the sensor :(
The sensor still works, will see over the weekend when i launch it if it is now watertight.
Should i be concerned re the grease exiting from the top ?
If i decide to remove the sensor, there is a bolt into the steering arm forward of the sensor holding a tag down
Just undo that and it lifts out ?
And when the sensor is off can i then clear the blockage downwards to the rotating plastic wheel ?
