DP-SMTD3 (Volvopenta sterndrive) noise
  • Thread starter Thread starter JBA
  • Start date Start date
JBA
New Member
6 Nov 2017
Last summer I bought a boat with VolvoPenta D3-160 A-A engine and with a DP-SMTD3 2.11 outdrive. Engine is 2005 model and has approx. 400hours in it. During the summer I found out there is a clanking noise when the engine is running on neutral gear and the noise was a bit louder when the boat had just been driven (warm oils I guess). In my opinion there was nothing wrong when driving the boat with cruising speed.
Boat was then lifted up for inspection and a guy with long time experience with boats (but not certified VP mechanic) checked the u-joints, bellow and gimbal bearing but found out nothing which could explain the noise. I also had a chat with some certified VP mechanics when visiting VP dealer to buy maintenance parts and they said that most likely it's nothing serious but in this type of outdrives there is a pretty big play between the teeths and that makes the noise.
Now when I lifted up the boat for the winter and ran the engine for freshwater rinse and glycol treatment I found out the noise to be pretty loud when the drive unit is completely out of the water which obviously filters the sound. And in addition the sound is almost the same with neutral gear or forward gear (didn't try reverse) at least when there's no pressure on the propellers. I changed the gear oil but it didn't have any effect on the noise and I think the old oil was ok in colour and I couldn't find any metal pieces from it.
This is my first post on the forum and I'm not familiar with attachments so here is a dropbox link to the video where the sound or noise can be clearly heard:
https://www.dropbox.com/s/xqeu34qssp9r58e/IMG_5791.m4v?dl=0
Are there any opinions whether this could be normal or is there a definitely reason to take the outdrive for a certified VP dealer for disassembly and inspection.
p.s. Sorry for my bad English, I'm from Finland.
https://www.dropbox.com/s/xqeu34qssp..._5791.m4v?dl=0
Link not working here !
It could be teeth chattering. Have you tried upping the revs a little to see if it disappears?
Many car gearboxes do this....
I've tried to rev up (a bit) but that doesn't affect the noise. I think that it was indeed gearbox chatter which those VP mechanics were talking about but I'm still concerned if that is normal or tolerable because in my opinion my drive has it pretty loud.
In all my years with VP I have never heard noise like that on those drives, I think you need to have the top off to check the condition of the gears and if its got the correct clearance and preload on the bearings.
I had a similar sound on my dpe drives but they were at around 1200h before it started. I m not a 100% sure but think it was play around the cone, the axle and cone being a bit worn and when not in gear it would rattle a bit.
My memory is a bit slow slow but I think it went away when I put it in gear so that could be a test for you.
I think the sound goes away when in gear and in water but the sound definitely stays there with gear on and out of water and no pressure on yhe propellers.
