DP-G Outdrive
Sunset Rob
14 Mar 2025
Hi All
Just completed oil change on my drives which were fully lifted to drain and refill with oil. the port drive refuses to trim back down. the display after it reboots shows only a flashing red and you can make out a click (I think from the pump relay) when the down switch is pressed. I have tried resetting the fuses on the black box but it made no difference. Anybody had this happen before and any advice on what to do. Thanks
jon and michie
28 Dec 2014
Swap the relays over to see if one of them has gone - coincidence maybe but anything is possible.
Was the drive trim a bit sticky before - could be the trim switch as they give up the ghost - maybe swap that over.
