GHA
Is there such a thing off the shelf anywhere?
It's to switch a bilge pump in a deep bilge where a normal switch just ends up in the pump cycling as the water drains back down the exit pipe lifting the switch which fills up the pipe again......
Tried a search but nothing much came up.
A double float switch, one above the other into a latching relay should do the trick.
If such a thing exists....
