Double eared hose clamps
I think there is a special tool for removing them, possibly a tool for fitting and removing them ??
To give an idea of the pressure there is in a fuel return line ... the return hoses on the car just push on, no clips at all.
I have seen the tool for fitting £13 I don't know if it is the same tool to remove them but seems a lot for 2 clips which I will probably not use again
Unless you're a manufacture fitting hundreds, is there any reason for preferring them to a decent Jubilee clip?
They strike me as horrible things to have to deal with in a blow, while you're head down in an engine compatment with diesel slopping around and the crew's screaming that the rocks are getting closer :eek:
