PotatoNavigator
The topic of open seams came up on another thread, I mentioned my issue on there but thought I'd best start a new thread so not to hijack the other one.
I'm currently restoring a double diagonal motor boat, it's in the water at the moment and there are no issues with the seams below the waterline. The problem I have is with the topsides, the original calico layer has perished away meaning you can see daylight through the hull at the plank intersections, also it is allowing water to get in between the layers.
Since she's already in the water there's not going to be any more take up (which is restricted by the copper bottom) however I can't fill the seams with anything hard like epoxy since there is still movement in the seams; in summer they open up, in winter some close completely and others close slightly.
If I put something squidgy in in summer, it will squidge out in winter fine, but then come the following summer the planks will open back up and the gap will re-appear. If I put something like sika in in winter when the gaps are smallest, there's no risk of damage, but in summer when the planks want to open, no doubt the bond will fail and I'll be back to square one.
Does anyone have any good suggestions or experience of what to do in this situation?
