ErikBenson
My 1953 ex Royal Navy Fast Motor Dinghy had a bashed in bit of floor
Situation at the moment.
I have cut out the damage in the floor -ie a rectangle (about 2' by3') from keel across to chine of both top and lower planks. My intention was to replace the inners with marine ply ( already cut and ready to fit.)
I then removed all the outer strips which cross the hole and have made new ones,-( the mating edges are not absolutely perfect against each other, but I had thought to bond and fill with 5200).
All is ready to fit back up. . .however I now have some serious questions as to how to procede.
I have not attached anything permanently.
I had thought to treat all the wood in the repair patch with epoxy to seal it before fitting. This would also allow me to leave out the cloth membrane and replace it with 3M5200, thus giving a complete seal.
Problem- what do I do to the rest of the hull?. . . .ie- I cannot get the epoxy resin in between the double diagonals. . .and if I treat only one side of them the wood will warp and possibly pull out rivets when the other side gets wet on the inside.
Also . . .the boat has been out of water for many years and the outer double diagonals at the front have quite wide gaps between them , partly clogged by old paint.
Because I will be trailering the boat and not leaving it in water to swell the wood , I need to have some form of permanent seal.
I read that it is folly to just fill these gaps with Sika or 5200 as the wood when it gets wet would have nowhere to go and pull out the rivets again .
Then I read that glassing the bottom , out to the chines is acceptable and has worked for ages on some boats. Even the BMPT have done this to their example.
If I take this course, maybe I should not use the ply patch but refit in untreated wood and use a cloth membrane. This would keep the boat as original , but not solve the dried out rest of the bottom of course.
What to do next ?
Finish the repair as original , and turn the boat upside down , rake out the old paint and strip all paint off and then glass the bottom.
To protect the wood. .do I then treat it from the inside with some sort of anti-rot product/paint ?
Note:
I have Don Danenburg's worthy forum telling me to replace the whole bottom of the boat, or stay near the beach ! . . . and then I have Jim Trefethen's book saying glassing is perfectly acceptable.
Life is short, and I just want to 'mess about with my boat", not rebuild the Ark.
Apart from the aesthetics matter, would it be possible to reverse this move some day if someone wanted to restore the boat to totally original?
AAAAAAAAAAAAAAAAaaargggggghhhhhhhh.
Any suggestions , however rude or impractical will be considered.. . .spring is in the air.
What to do next ?
Note:
