ianainge
Had a problem with my domestic water pump, it was not switching off took it out and repaired the pressure switch ,tested it out of the boat all o.k.refitted yesterday but now it wont switch off when you trip the switch on the main control panel, it use to before, any ideas ?. i discovered this because for some reason its not pumping the water through but that might be an air lock, so the pumps just runs continuosly.
