NealB
Our fresh water system has been steadily deteriorating.
The pump cycles, but no water flows.
I can suck water through, and the system works until I switch the tap off. Pressure falls quickly and the pump cycles continuously again, but no water flows if a tap is re-opened. It won't prime itself again.
We don't have any obvious water leaks on the outlet side of the system.
If I disconnect the outlet at the pump, and put my thumb over the outlet, pressure builds quickly and the pressure switch turns the pump off. Pressure remains, and if I slightly release my thumb, water sprays everywhere, pressure falls and the pump kicks in again. Squeezing my thumb to stop the flow again, and the pump cuts out.
I interpret this as evidence that the input side of the system is working ok.
However, if I attach a hose from the mains into the outlet side of the system (so mains is providing pressure not the pump), all the tap outlets work fine.
Which makes me think that the 1992 shurflo pump isn't up to the job any more (ie contradicting my first interpretation).
What is strange, to me at least though, is that the flow from the pump seems much greater than the pressure we were putting in from the mains (we only opened the mains hose tap slightly, to avoid blowing all the connections).
Does the esteemed panel have any observations on this, please?
Are there any other tests I can do, or do I just gird my loins, and lash out on a replacement pump and hope that's the problem?
Thanks for any advice.
