toad
I have a Shur Flow water pump supplying a galley sink and shower head through a calorifer, the pump has died and is not repairable. As I intend to launch next Saturday a direct replacement is required in the next week, a replacement from Amazon is about £55. Looking at the old pump it has a flow rate of 10.6 litres a min and a pressure of 30psi which seems a bit high to me as I often have to tighten up the pipe connections. I think the pressure is adjustable by the screw on the end or I can buy the next size down which is 7lh and 20psi. Can anyone confirm that the pump pressure is adjustable in this way and what pressure do others run there system at. I have done a search and the only post that I can find seems to suggest a pressure of 15psi.
