claudio
I've seen mention of Asus eee pc notebooks for use onboard. Just a warning that the 900 model has an 'undocumented feature' of discharging the Lion battery whilst it is switched off. The battery will be completely discharged in a couple of days of non use. I spoke to Asus about this and they said it was a motherboard 'design fault'.
My recommendation is avoid this model completely as there tech support will ask you to return the machine to them for a motherboard repair. This may take 28 days.
Otherwise, it looked quite an attractive solution for onboard use.
