Heckler
Info coming in from my other thread led me to this http://strathprints.strath.ac.uk/5670/1/strathprints005670.pdf
Stu
Stu
Just read that and am still confused. If I have a 2 blade folding prop can I be in reverse?
RoyStu,
I have not read every part of the document but P24 seems to confirm that preventing the prop from rotating increases the drag. One other aspect not dealt with in this report is whether locking the prop will damage the gearbox. When I contacted Volvo Penta about the VP 2003 diesel engine and MSB2 gearbox combination they said that the prop should be allowed to rotate. Of course, this is not to say that it applies to all engines/gearboxes.
Roy
I suppose that a good idea would be to put a spot of paint or line on the top of the shaft, indicating when the prop is vertical?It took a while to get to the point but they seem pretty sure
"The experimental results confirm that a locked propeller produces greater drag than
does a freewheeling screw (up to 100% more drag was observed, this being at higher
speeds). Furthermore, for the freewheeling case, the magnitude of the hydrodynamic
resistance is significantly affected by the amount of frictional torque on the shaft, low
torque being accompanied by low drag."
I don't know how this would equate to speed difference but I think I'll keep my 2 bladed prop locked to cut down on noise and wear and tear.
1 Can you measure the difference in speed under sail with locked or unlocked prop.
You would think with their test tank they could tow a boat with a constant force and measure the difference in speed. Or you could get a tow from another boat on a flat calm day, boat in front keeps engine at constant throttle setting boat behind has freeweeling prop then a locked prop and measure the difference.
Or in a practical way, just take it out of gear and see what the speed difference is - have done this with no consistent difference!
Stu
No it requires energy to turn the prop so letting the prop will use more energy that allowing it to freewheel. Consequently, locking the prop will give less drag.
