Woodentop
There is an irritating bit on the Navtex that just wastes paper and is torn off and thrown away ; or if you are listening live, the boring bit after the weather; these things called Whiskey Zulus.
In mid Channel a rather clever Dutchman is using all kinds of remotely controlled stuff to cut holes in the cargo vessel Ice Prince and remove the heavy fuel oil. (It sank last year - took a while for the clever gear for deep oil removal to be designed and built)
The wreck is at about 50 metres (plus) , the heavy fuel oil has to be heated to 50 degrees centigrade to flow, there are about two thousand tons of the stuff and the British Government has said that it will be removed.
So the Vos Sympathy is on station doing the business. Any vessel which goes close will be entering a Total Exclusion Zone and thus committing a criminal offence. (Which is explained in the boring bit you never bother with).Today a Belgian yacht passed 10 metres off Vos Sympathy - and thus 990 metres inside the TEZ.
Last week it was a Channel Island registered boat which came too close and whose owner is about to gain a criminal record.
Did you known that you could get a criminal record (and hefty fine) from sailing across the Channel and being totally unaware of an Exclusion Zone ?
