Davydine
Good morning,
I have a Thornycroft T90 engine which is a little reluctant to start. It needs at least 30 seconds of heat and then has to be cranked for about 10/15 seconds before starting. When it does start there is quite a bit of white smoke, which gradually reduces as the engine gets up to working temperature. The engine seems to have plenty of power, but since we have just got the boat I have nothing to compare with.
Do you think that the injectors may need servicing, and if so, can I remove them myself and can anyone recomend somewhere in the Essex / Suffolk area to get them serviced?
Also, can anyone recommend a good guide book to diesel engine maintainance to help troubleshoot problems.
Many thanks,
David
Many thanks,
David
