PhillM
So my MAB was never designed to have jackstays. We do have fitting points and for the last two years I had a set of the Baltic adjustable jobs. I now need to change these and have bought pre-made ones.
With the high coach roof and general shape, there were two places where the old ones rubbed into the varnished wood and when you walked along. the metal clip (of your line)would hit the coachroof and cause scratching / minor damage.
My new pre-made jack stays are about 4 inches too long. This means that they cannot be tensioned. In one way, I quite like the fact that by being slacker they are not putting pressure where the old ones rubbed. However, they do look really slack and dont lie flat.
My proposal is to attach the lines using the proper sewn loops but then to double back enough material to shorten them enough to make them lie flat - then whip the two parts together. My thinking is that in general use the lines will lay flat and not damage to the boat and in emergency, if the whipping failed, the jackstay is still connected through its proper loop.
Comments, suggestions please.
