topcat1
New Member
Hi all i have just antifouled my boat and want to know do I also do the legs in the same paint?
Cheers topcat1
Cheers topcat1
You must use antifoul specifically designed for use on aluminium. If the hull antifoul is copper based, then don't apply it right up to the legs, leave a gap of about an inch.
I used International etch primer followed by Trilux spray on the drives and it has worked OK.
That will because the white one contains cuprous thiocyanate rather than cuprous oxide. Trilux contains cuprous thiocyanate.This year I've painted it with white EU45 which is supposed to be okay on aluminium.
Cheers topcat1
