do I grease an electric motor
galeus
12 Mar 2005
Ipswich
I've got my Sealand electric black water tank pump in pieces as one of the carbon brushes was sticking ( now sorted) and I can see that it all looks a bit dry in there.
There is an enclosed ball bearing (ie I can't see the balls) at each end of the commutator and a spiral gear on the end of the shaft.
I'm thinking of sparingly putting grease on the spiral, but the best I could do with the bearings would be to drip some 3in 1 there.
It all seems to be running fine and is about 15 years old.
What do you think?
Is your spiral gear a worm and wheel arrangement? I would grease it with an EP type grease as this type is quite heavily loaded with a high sliding component.
I can't see what the spiral gear engages with, though I can't imagine what it can be but a worm gear.
I think I will take Grahams advice about my 3in 1 thought (ie don't) and just paint a minimal amount of grease (EP type) on the spiral gear.
Thanks Richard
Te brushes wear, giving rise to "carbon" dust. Any grease in the motor will attract the dust and eventually turn to "pudding". On the other hand, carbon is not a bad lubricant and on small electric motors with worm drives, I have used pencil lead as a "lubricant" on the worm and wheel.
About grease on spiral bevel gears. I have a DeWalt 115 angle grinder. For reasons I can't remember, I opened up the gearbox fairly early on and found there was no grease in it?? Spoke to the vendors who said they would replace it if it went wrong at any time. But they where not sure if there should be grease in it.
Well over 15 yrs later and used daily, often quite hard, it is still fine.
