Longshanks
Just found a little group of osmosis blisters beginning to form in one part of the hull. I suspect the moisture may have come inside rather than outside through the epoxy coating and with a bit of luck is limited to this small area only, so I'm going to tackle this myself. I think there's a PBO article on this somewhere, but what does the forum think? My plan is to grind out the individual blisters, rinse well with water to get rid of any solutes, let dry for a day or so and then fill the craters with epoxy filler. Top coat locally with more Gelshield then keep a good eye on the area over the next year. Who else has done something similar? Did it work?
