pcatterall
Hopefully my photos will have uploaded. Its ages since I added any and I keep forgetting how to do it!!
Now we are mainly mooring stern or bow to we thought we needed to investigate the issues of getting aboard and decided we needed a gang plank and a way of getting our little old legs over the pushpit.
For the gang plank ( when tarted up it will become a ‘passerelle’) we are using the ‘ships ladder’ with light ply board over the rungs. The ladder will ( next project) also go over the stern as a boarding ladder ( held away from the inward slope of the transom by a large fender)
The shore end of the plank is suspended above the pontoon by bungey cord from the mizzen boom and the boat end by lashing to a fitting, this end is work in progress and if anyone has any bright simple ideas they will be appreciated. As ever we dont want elaborate fittings which need to be removed to sail or which get in the way when sailing.
You can see ( I hope) that the pushpit top rail has been cut but can quickly be replaced using the T fittings. I was going to remove a section of the lower rail and fit 2 more uprights to the deck but the existing measures seemed fine and some of the original strength has been retained. It would be nice to find just a straight connector rather than the T pieces but I cant see one in any catalogues. In fact only one connector is really needed as the port side of the rail uses an ‘inner tube’ to effect the ‘join’ Possibly I could make a ‘connector’ with a length of SS tube of 25mm ID to slide over the top tube and secured by a screw or through bolt.
Any comments which would help improve the pushpit gate and the gangplank arrangement will be appreciated.
