DIY liquid sensor (bilge pump switch) circuit.
rob2
23 Aug 2005
Hampshire UK
I seem to recall a piece in PBO about a liquid sensor circuit, which received a "correction" from another reader the next month to make the circuit electrically fail-safe. I've spent most of a day going through copies, but have obviously missed it. Can anyone advise me of the relevant issues, please?
Since a rather neat unit from Rapid Electronics with gold plated contacts is available for £3.86, I am rather tempted to use this type. http://www.rapidonline.com/Electron...w/78-2090?source=googleps&utm_source=googleps
Rob.
The Rapid unit sounds like a good idea. Making up a suitable DIY version would probably cost more and it's always difficult to produce a housing that looks OK.
Having checked the Spec for the Rapid unit (see below) just make sure that the switching capacity is adequate for your pump. 10w seems a bit low.
Contact form Form A normally open
Switching voltage 100V DC max.
Switching current 0.5A max.
Switching capacity 10W max.
Contact resistance 0.5Ω
Operating temperature –5°C to +80°C
Case material White plastic
Liquids Non corrosive. Not heavy oils
Cable Twin core insulated. 1.8m
Afterthoughts:
1. Salty John has a floatless switch for bilge pumps - don't know how much though
2. Anything is better than the Rule float switch
Yes, the capacity is rather low for a direct switch. It was the switch circuit I was after. Being a compete ignoramous in circuit design, I was hoping to find something to copy. I was thinking of banking three sets of contacts to give off/on/alarm, using a relay for the power feed to the pump.
Rob.
1. Why would you need a signal for 'off'?
2. Relays are adding to the cost and need to be 'marine quality'
3. You might be better to source a higher rated switch
Off? Well, I was thinking hysteresis. Middle contacts switch pump on, lowest contacts switch it off and the top pair tell you to man the bilge pump - the electric one isn't coping!
Rob.
Hysteresis. Thereoretically you wouldn't want the pump cutting in/out too often but with a reasonably sized bilge I don't think a seperate contact for off would be necessary.
Unless you really like spending time making DIY circuits, why bother.
I fit electronics on boats and just use a readymade solid state sensor and microprocessor which costs less than £30 and will outperform a float switch.
or-
washing machine pressure switch. Remotely located above water level with small pipe to bilge terminated in a plenum chamber (inverted plastic bottle on Magna)
Good switch on/off differential, adjustable if required. Reliability? Put more than one in parallel if you feel the need. I twinned mine to a 'marine' float switch which failed in less than a season! No relays used on my setup.
Nick
and also
Nick
We got fed up with our float switch clogging up and sticking. Changed it for a 20(?) amp solid state switch, very clever... ;) Two years later, absolutely no problem. 3 year guarantee too. :) I think it cost under £20
Thanks for the replies. I was looking at several different types and the washing machine pressure switch would work well on my boat as I have a sump above the encapsulated fin keel. The reason I was also interested in the resistance type or the reed switch type is that A colleague with the lifting keel version nearly sank after launching due to developping a continuous drip from a skin fitting. He has only 3" under the cabin sole, so a really compact detection system is called for in his case (I believe the pressure sensor typically requires a vertical tube at least 6" long).
Rob.
