Lomax
Being the paranoid type, I have opted to weld up and close off all the through-hulls under the waterline on my boat, other than the water intake for the engine. That means I have to have a discharge pump on the grey water, sucking it up from a sump tank in the bilge and draining overboard. The problem is, the free height between the stringers is only 16cm, and I don't want to fit a tank that sits flush with the inside of the hull as it would become an inevitable rust spot. Leaving an air gap of a couple of centimetres underneath the tank means I only have ~14cm height, and I haven't been able to locate a suitable tank with such a low height. Capacity wise I don't think I need more than 6-10 litres of volume (for example, the small Whale grey water sump is just 8 litres), but it needs an inspection hatch, and preferably a transparent lid. After scratching my head for a while, I came to think of IP67 rated electrical enclosures like this one from Fibox:
What do you guys think, any reason why this wouldn't work?
