vyv_cox
Air cooled condensers can be adequate but at high external temperatures they are not as energy efficient as water cooled. On a hot Med day where the air temperature could be 35 degC and the sea temperature say 25degC you would have a 10degc advantage by using sea water to cool the refrigerant. This lower condensing temperature translate to less power used for the same amount of cooling. I am not suggesting you need to go water cooled for this project. I would use a small waeco air cooled unit. This will be ample for this application and not too pricey.
The post that you replied to by Charles Reed highlights the difference between installations and boats. His custom design fridge has massive insulation thickness and he is able to draw cool(ish) air from the bilge and route it outside once through the heat exchanger. On my Sadler the bilge is not cool because of the hull insulation and the route for air past the heat exchanger is tortuous and inadequate. It also vents into the saloon, making it even hotter in the Greek summer. Fitting a water cooled Danfoss unit to a standard Waeco fridge transformed its performance, the pump draws less then 1/2 amp when the fridge is running, which is somewhere between 1/4 and 1/3 of the time, 24 hours per day.
