2copplane
I've two heads on my boat and am considering converting the guest one to electric. Primarily as I have a young daughter who just will not flush manually. I also have the perennial rotten egg smell when it is first flushed.
However I'm far to tight to spend £300 on a new electric one, and would continue to be smelly.
As an alternative I'm pondering taking a solenoid valve controlled fresh water feed to fill the bowl, and fitting a macerator to evacuate. The valve and pump off eBay would be around £60.
I would fit a three way switch so up would fill and down would empty.
I could possibly set it up so I can leave the existing manual pump in place so it could be used to fill with sea water if at long term anchorage, saving fresh water.
Next step may also be a small holding tank for when no2 beckons and the marina loos are just too far.
Would it work?
Would it work?
