pcatterall
Begining to despair in trying to locate the correct connector for my Webasto heater ( someone has chopped it off the loom)
I can buy the whole loom for £70 but that seems alot for a plug!
I have found the correct size female terminals but not in a block to suit the staggered 6 pin male block on the heater.
I was thinking of pushing individual terminals onto the pins and then filling the plug with resin. I would fit a universal type 6 pin disconnect block on a short tail from this (now permanant) plug.
This is all low power stuff going to the units timer and to the fuel pump.
There is around 2mm clearance betwean the terminals when they are pushed onto the pins.
Is this a possible solution or am I mad?
