MarkGrubb
Hi all,
I'm refitting the galley and nav table in my boat. I've made a new top of the nav table and a new galley top, as well as shelves underneath. All out of 12mm exterior ply.
All tops and shelves are supported by battens on three sides, which are screwed into the surrounding bulkheads.
The boat's fibreglass hull is on the fourth side. I've made the tops a very snug fit, so there is very little distance between them and the hull.
However, I was reading that when fitting wooden bulkheads in a fibreglass boat, there should be some clearance (around 10mm) between the bulkhead and the hull, otherwise their will be a hard spot, and stress marks, cracks, or gel coat crazing may develop because the hull can't flex properly.
My question is should this rule be applied to all fittings that butt up against the hull? Should I cut 10mm off the depth of my table tops to allow clearance for the hull to flex?
The woodwork is currently in my shed for sanding down and varnishing, so alterations can be easily made.
Advice and comments appreciated.
Thanks,
Mark.
Thanks,
Mark.
