stevecal
New Member
Apologies for previous post. Don't know what happened. The rudder on my Bav 32 has stiffened up. The lower bearing apparently gets pressed hard against the stock by corrosion building up behind the bearing. On removing the rudder the bearing was seized solid in the tube. It needs to be rotated 90 deg to remove it. Is there any chemical that I can put down the tube to dissolve the corrosion? I don't think the bearing is badly worn and am hoping to save it rather than cutting it out.
