Ric
Hello,
The impellor on my Yamaha 2hp 2-stroke needs replacing.
I have taken the bottom end off the motor at the cavitation plate, including the drive shaft, without any problem.
I undid the bolts on the impellor housing and lifted it for about 2cm to expose the old impellor. But I can't slide it all the way up the drive shaft to remove it and the impellor as the drive shaft widens about 2cm up. It seems that the drive shaft is made up of a wider, outer tube, slid over a smaller shaft. How do I get this apart?
I have tried taking off the circlip at the gearbox end of the shaft - but this does not help either. There is clearly something else preventing withdrawal of the shaft from the lower end.
I have spent hours googling this problem this afternoon. I even took it to a Yamaha outboard dealer this afternoon, and he didn't know either!
