DIW
Does anybody have a 'magic' solution (no pun intended!) to remove the mould and discolouration from white mastic sealer please ?
Try acetone and a toothbrush.
Just a question.........doesn't the acetone soften the mastic, making the surface sticky?
Thanks, Allan
If you choose to replace it, then unless you've done lots of mastic work and have a very steady hand its all too easy to make a real hash of it, and have excess silicone everywhere. I'd run masking tape along both edges, just leaving the gap you eventually want the silicone to fill. This takes all the expertise out of it, and you can keep running your finger along until you have the right amount of silicone remaining, then remove the masking tape and you'll have a lovely proffessional job with nice straight edges.
How about just wiping it over with bleach?? Just a thought.
Lisa
Dunno why this post has played on my mind but it has and I woke up this morning and thought...how about a grout pen? Worth a go??
Lisa![]()
