bluedragon
A strange request I'm sure, but for those of you who have read my recent posts you'll know why! My question is how to safely disable an alternator whilst having it available for use when needed. I could do it mechanically (take the belt off) but what I'd like to do is to have some electrical means of doing this...that is having the alternator turning but not producing (or consuming) power. I know that if an alternator is suddenly disconnected from a battery whilst producing power, the voltage spike can kill the diodes. But what about if it's disconnected before the engine is started and no exitation has occurred? In principle it won't produce a voltage and therefore no problem...but I have a feeling it's not that simple? What about a switch or relay in the field coil circuit or the warning light feed? As long as this is before engine start, would that present any risk to the unit? Any ideas on how else I might achieve the same effect i.e. taking an alternator electrically off-line?
