You need heat and patience. I did this last year and after seeking professional advice the recomendation was to use a heat gun on the pad and slowly peel it away. The heat breaks the glue down, so start at one end and after a while you'll find the glue softening and you can peel the edge of the pad back, though you seed to apply a reasonable amount of force. It took me the best part of a couple of hours per pad. You need to be careful to keep the heat gun off the dinghy fabric and don't be tempted to use tools to lever the pad off. Heat and patience....
