Dinghy Sail Logo
Lakesailor
15 Feb 2005
Near Here
I bought some sails for my project. They are a main and jib from a Topper sized rig, and although the main has a luff pocket to go on an unstayed mast there is also a small jib.
I haven't a clue what it's from although there is an anchor as the class logo. Any ideas?
I'll take a pic shortly.
sailbadthesinner
3 May 2002
Midlands
topper did a sort of small version of a drascombe that had a little cubby for an outboard and and a sleeve main and a mizzen
it was the cruz
but cannot remember what the marking was. not sure it was an anchor tho.
you did not buy this from one of them there cockerneys did you lakey?
Lakesailor
15 Feb 2005
Near Here
here they are.
Atkinson21
7 Apr 2007
Having been a lurker for some time I can now make my first venture on to the forum with something positive.
The sails are from a 10ft dinghy that was and possibly still is marketed by a company called Fibrocell. About twelve years ago they were based in Oldham, Lancashire.
We used to have one of their dinghies as a tender for our boat.
I believe the rig was actually stayed with the shrouds and forestay attatching to the mast through the gap in the luff sleeve.
Lakesailor
15 Feb 2005
Near Here
Ah. I've Outed someone.
Thanks for that. It's not important except that I like to know these things. It's going on my trimaran which I'm basing around a 10ft skiff. Interesting about the forestay. Ther's quite a lot of sail there. I may put a short bowsprit on and use that.
I did a P/shop design for it in October last year
And now it's underway
Lakesailor
15 Feb 2005
Near Here
believe it or not they are just cut from two sheets of ply (for ease of duplication and have a straight keel and top edge. Drill and wire them together and open them out. The inserts are the tricky bit to get right. It leaves it with a rather pleasant sheer. Then I've just put a bead of epoxy mixed with wood dust and silica in the joint.
When it's set I'll tape and epoxy the external joint, as much for abrasion resistance as anything. Tricky bit will be bonding the deck on.
I have an old main from my foxcub and a friend has an Enterprise mast so there may be some developments in view once I've got it sorted.
This would be the ideal finished product.
cameronke
31 Jan 2003
Clyde,Argyll, Scotland
Ah stitch and glue method if I remember correctly. Finished results look really good!
I started messing about with some ideas on my CAD using twin windsurfer sails as per old Hobie Tri-sailer....
Got some improved drawings at home with hydrofoils and will try and find them.
Now learning superior CAD software that will hopefully provide more scope
Cameron
Searush
14 Oct 2006
- up to my neck in it.
back2bikes.org.uk
Wasn't the little Fibrocell dinghy called a Dolphin (with said fish on sail)?
I seem to remember "Skipper" dinghies with an anchor on the sail, in a range of sizes that sailed abominably and almost always end up as O/B powered tenders or rowing boats.
But then, my memories are selective these days!
Lakesailor
15 Feb 2005
Near Here
Skipper Dinghy
Mine sails are apparently from a Fibrocell Seagull (now I've got the manufacturer it all falls into place). Looks a bit shite, but will power my project well enough.
