marcot
The analog voltmeter - Vdo - displays 30v when charging from shore the 24v battery bank while the digital - mastervolt reads 28,8v. Never done before. Could it be a problem?
Are you asking about the difference between the two readings or the relatively high voltage of both of them?The analog voltmeter - Vdo - displays 30v when charging from shore the 24v battery bank while the digital - mastervolt reads 28,8v. Never done before. Could it be a problem?
The answer is yes, to both questions.
Correct, perhaps I wasn't being clear.?????? ......... 24 volt battery! ..... RTFQ ( F=full)
The internal resistance of the analogue metre is much lower (10x lower) than the resistance of a digital metre typically 20MΩ. The metre resistances is in parallel with the circuit, the high resistance of the digital metre will take less current from the circuit being measured, the two metres will give different readings. The digital one will be more accurate.
It is possible that your charger is not sending out pure DC, the two meters respond differently to the ripple voltage?
