wijnendael
On our recently purchased boat I have been checking the wiring to the instruments one being a digipak S depth sounder and the other digipak L loch speedometer. I found that the connection had been made incorrectly and now that they have been corrected the units come on and the displays are working. The speedometer appears to function ok but not tested while boat is driving yet, the paddle wheel seemed ok when checked while the boat was out the water. The depth sounder I found has had the wire damaged near to the transducer and a connection made in it, after connecting the unit correctly the unit is flashing SOND continuosly which i think means the transducer is not connected. For this reason i will trace the wire all the way back through the boat to establish if here is anymore damage. My question is in the manual it states that if the wire has been cut or damaged the transducer will require replacement is this true and if so does anyone know where i can obtain a replacement unit
