portvasgo
Active Member
Sailing the north coast of Scotland as my home waters, there is little VHF traffic, I therefore use it rarely. However towards the end of last summer, I hailed one of the local fishing boats, he heard me clearly, however I could not pick up his reply. I further checked this by calling Aberdeen Coastguard, and it seemed they received my signal as I heard an attempted reply - only static. I therefore assumed there was something wrong on receiving signals. However, I did not know whether it was the VHF unit or the aerial.
During the winter, I put my VHF unit onto the aerial in another boat, and the result has me totally bamboozled. With the use of a hand held VHF and putting my VHF on the other boats aerial it seemed the opposite problem was happening, that is - the VHF was receiving ok but not transmitting!
At the moment my boat is demasted and it is therefore really difficult to connect my VHF to my own aerial, so I'm left still not knowing what's going on, anyway if I use my own aerial I'm back to not knowing which is at fault - aerial or unit.
Does anyone have any idea what might be going on, I am starting to doubt whether I have got mixed up with what was happening in the summer.
My main question is. If it is the aerial that is at fault would both transmission and receiving be affected. I.e. if it was the aerial would everything be dead or static? Or should I just go and get a new VHF unit, I should probably get a new DSC unit, as my current one is quite old. But with my luck I’ll connect everything up when the mast is put back up, and it still won’t work!
Any advice would be greatly appreciated. Keep it simple though – as you can no doubt tell, I’m a novice at this!
Thanks.
Thanks.
