Diesel stain on Treadmaster
JerryHawkins
4 Sep 2001
Plymouth
Does anyone have any ideas on what I can use to remove an oil stain on my Treadmaster (diamond pattern) deck covering?
I've tried Jiff (Ciff) and recently some "Starbrite" non-skid deck cleaner. These have not helped much - I just have a "clean" stain now!
Cheers,
Jerry
I have used "Brake cleaner" to good effect, to remove stains from teak. I would think that you might carefully try some of this. Available from most car accessory shops? Try a small area that doesnt show first, in case it reacts with the adhesive bonding material.
Rob
<hr width=100% size=1>robinwdunham
Thanks...
I've tried white spirit (as suggested by PVB) with no effect. Brake cleaner seems worth a try - I think this is based on trichloroflouroethylene (sp?) or "trike" (had dire health warnings if I remember correctly!!), and was the main constituent of an industrial de-greaser/cleaner called "Ardrox" which I used years ago. I'll get hold of some and give it a try!
Cheers,
Jerry
