tolhurstorganic
My Pinky Ketch has a 28hp Betamarine connected to two diesel tanks, custom built by Tex Tanks, these are deep in the bilge below the level of the engine, capacity is #1 190 litre and #2 100 litre. The return pipe from the diesel pump is routed back to the tanks via a “T” and then into each tank (#1+#2), there are no separate valves to turn off the return fuel to each tank. I usually run the engine on one tank until near empty then switch over to other tank, closing down the near empty one. Last week went for a sail to Portsmouth from Emsworth used the engine going as it was a dead header and sailed back.
When I left Emsworth I had equal amounts in each tank-half full. On returning from the trip and checking my fuel level in the tanks I find that tank #1 which I ran on was empty, whereas the tank #2 that was not used was full. It would appear that the return fuel all went back to #2 tank instead of to its original tank. I used to run on both tanks, which would go down at an equal rate and never had problems with the return fuel going to the wrong tank.
How do I ensure that return fuel goes back to its original tank, put a separate valve in on each return pipe to route the fuel when I change over the tank? Any ideas will be much appreciated.
