dunedin
About to replace the fuel filters for the first time since getting the boat.
Installation seems to have an electronic + manual fuel cutoff, then a large in-line fuel filter (Crossland 5005 seems to fit) then the small filter on the engine itself.
Clearly replacing these big fiilters will let an awful lot of air in. So how best to prime the system and get the air out?
* is the little lever just in front of the engine filter the priming pump ?
* where do we start from the line filter then forward ?
* do I need to open a vent at each filter only or right at the injector (assuming I can locate this) ?
And I managed to switch off the fuel input supply with the manual switch under the solenoid, but will I need the engine "ignition" on to allow diesel through to do the priming ?
Apologies for the daft questions, but no manual came so not been able to RTFM !
