seaangler23
Going to fit a 4kw planar to the boat and the only place I can have it is in a locker in the wheelhouse (motor sailer) so the exhaust skin fitting will have to go as high on the side of the wheelhouse as I can get it (above heater night) with hopefully a bit of a swan neck then looping down under the heater.
There isn't an ideal spot that won't see any spray while sailing so the exhaust instal will always be a compromise, may make a bung and be careful to remember to take it out and put it in or toyed with the the idea of a clamshell over the exhaust but that's likely to restrict flow and create a nice hot metal object protuding from the wheelhouse instead of a flush one.
Anyone got any ideas of how to go about this? Has anyone tried these exhaust drains and do they work or will it just leak exhaust fumes into the locker and into the wheelhouse? Can knock one up easy enough if they are any use
http://pages.ebay.com/link/?nav=item.view&alt=web&id=121414790365&globalID=EBAY-GB
