neil1967
Hi
I have a CAV diesel filter connected to my Beta diesel. I recently replaced it because it was leaking, but the replacement leaks too - apparently from the seals between the glass bowl and the metal fittings. Is this a common problem and how can I remedy it? The fuel tank is about 10cm above the filter, so there is a slight positive pressure, but I still wouldn't expect the filter to leak. I turn the diesel off at a tap between the tank and the CAV when not in use (in port), but I wouldn't want to turn this off when at sea - one more thing to remember to turn on when needing to use the engine!
As always, your collective wisdom much appreciated!
Regards
Neil
Regards
Neil
