Diesel exhaust
Sheerline
23 Oct 2004
NSW Australia
Above 2800 rpm, my new diesel engine makes the boat squat and puts the exhaust below the waterline.
A friend's version of the same boat does the same thing.
Should I go through the hassle and expense of moving the exhaust - or should I ignore it?
sailorman
21 May 2003
Here or thertemp ashore
prior to re-engineing i assume it didnt "squat".
my sail boats exhaust goes under water @ just below cruising revs & appear to have no probs in 25 yrs.
r u getting full revs with new engine ,u might concider having a prop / props with less pitch, if not
Sheerline
23 Oct 2004
NSW Australia
It's so long since the previous engine was healthy enough to get that angry, I almost forget.
Yes it did, flat chat - but it didn't bury it like the new Nanni can.
The new motor gets more than its max revs - so the old prop needs more pitch, which will exacerbate the "squat".
MarkJohnson
2 May 2003
Swansea
On my old Halcyon 27, the exhaust outlet was below water anyway.
No problems encountered there at all.
The exhaust has to push water anyway in the mixing box, so has a certain amount of back pressure anyway.
billskip
6 Sep 2001
adjust the throttle stop so you cant over rev..if your happy with the speed of the boat that is..if you up the pitch you may find just knocking into fwd/rev on tickover for close quarter manouver it will be to coarse..after all it is a sail boat you dont want to waterski do you? ok I accept correct prop size is important but maybe the prop is correct for your hull design and you have got a more power from your new lump
<hr width=100% size=1>Bill
colvic987
2 Sep 2003
north west england
ignore it, make sure the water cannot be sucked back into the engine, maybe fit a swan neck to the exhaust just before it exits the transom, if it has not already got one fitted....my boat also squats when at cruising speed, and no problems occured over last 5 years...
