Engine run at various times through winter to check / change oil etc. etc. All seemed ok ... we thought we had a problem with overfull sump causing run on from lub oil getting up - but no all seemed ok.
Boat launched and engine started. All fine for about 5 mins ... then engine revved up to max. Stopped engine .... checked throttle cable etc. all appeared ok ... so adjusted idle stop screw back ... engine idling fine .... 3 - 5 mins and speeds up to max .... pull stop and engine dies ... put stop back in ... engine idles. Engine now is in state that it starts ... warms a little and idles ... then speeds up to max revs ... pull stop out and back in before it dies ... it idles again ... 2 -3 mins and back up again to max revs ..... pull stop and just before dies ... put stop back in again and it idles ....
When idling - engine sounds sweet as a dream ...
Engineer here says old diesel fuel ... but he has only listened today ... I think there is crud in the system ...........
Any diesel engineers like to suggest what it is ?
Engine is a Perkins 4-107 .... raw water cooled ... bit sticky on rings but never a problem before ....
Over to you guys ??????
