ProDave
I post this here as this sounds very much like similar problems that have been discussed with boat engines before.
I have a Peuogeot TUD3 Diesel engine fitted in my mini digger.
It's a pretty straightforward installation. the engine directly drives a hydraulic pump. the hand throttle of the digger links to the throttle linkage on the fuel pump, just like the accelerator cable did when it was in a car.
The fault I have, is every now and then, the engine will just race away to quite high revs all on it's own with no throttle input.
I don't think the problem is anything to do with the fact it's in a digger and not in a car. It really is a simple instalation.
Engine oil and coolant levels are fine. Only 30 hours running since an oil and filter change. And the hydraulic fluid level on the digger side is fine. Fuel is fresh red diesel.
any ideas please?
this sounds to me bit like the fault I have read about before where the engine is burning it's own lubricating oil via the breather system. but in my case I'm not sure if it is that, as the engine will stop on the key, so that says to me it's burning diesel?
any ideas please?
