Does anyone use an additive in their diesel. i.e. for helping to reduce sticking rings etc rather than killing bugs?
Any knowledge gratefully received.
Used to use Redex diesel treatment,but they dont make the same one anymore, as I have a steel boat and tank I had no trouble with rust or diesel pump problems as it had additives for both.they still add the additives for the pump etc. but not the tank. I now use Soltron and thinking of adding some 2-stroke oil to "oil" the tank and help with lube. on the diesel pump. anyone got any thoughts? wouldnt need much 2 stroke oil I would have thought.maybe a waste of time!!
Addition of Lube-oil ? All diesels pass a Lubricity test and red in fact is better for pumps than white .....
As to use of Soltron etc. - some dose each fill up - which IMHO is overkill. A tank is not normally full empty when a refill is made - therefore additive is still there ... but just gets diluted .... as the tank is free of problem - it is fully able to treat what is coming in ... My regime - IF I was to use such - would be to dose after so many fill-ups - determined as when dilution is so far down scale as to be near / at zero. Even then is it really necessary every time ?
Remember dose levels are nice for sellers and also are usually quoted higher then needed to make sure product meets sales guarantees. Seller sells a nice quantity and assures themselves of repeat sales ....
But maybe I'm being unfair ??
having bought a boat with a smokey volvo 2003 last year, I was given a bottle of a S African injector cleaner ring free-er type compound. Much to my surprise , it really worked.
I remember you had a lot of trouble getting your engine (Bukh) to go in the Spring - it showed signs of low or no compression. Mine wasn't quite as difficult as yours, but it still took an awful lot of churning and hairdryers up the air intake etc. I could turn it with the handle whether the valve lifters were on or off. During the warm Summer months I have cogitated on what I did over the Winter of 2005 to make the engine behave so badly in the Spring. The answer is - I took the exhaust manifold off to paint it and didn't put it back until the Spring. I think cold damp air got in and rusted the exhaust valves and thus destroyed the compression. Once the engine started up the valves bedded themselves in again. I certainly have plenty of compression now. This winter, I'm going to stuff oily rags down the air intake and exhaust and hope for easier times next Spring!
